Strange 1334 error with Window 7
Having trouble running Advanced Installer? Got a bug to report? Post it all here.
p_k_malone
Postby p_k_malone » Mon Mar 21, 2011 4:22 pm
We are getting avery strange 1334 error just with Windows 7. Not with XP, or Vista. It tells me that a file is missing from a cab. If I turn CAB compression off, then the problem goes away. Here are the lines from the verbose dump.
MSI (s) (54:88) [14:37:39:093]: Executing op: ChangeMedia(MediaVolumeLabel=Disk1,MediaPrompt=Please insert the disk: Disk1,MediaCabinet=1\setup13.cab,BytesPerTick=65536,CopierType=1,,,SignatureRequired=0,,,IsFirstPhysicalMedia=1)
InstallFiles: File: ABCpdfCE7.dll, Directory: C:\Program Files (x86)\AristaTek\PEACWMD6\, Size: 13889792
MSI (s) (54:88) [14:37:39:164]: Note: 1: 1335 2: setup13.cab
MSI (s) (54:88) [14:37:39:165]: Note: 1: 1334 2: ABCpdfCE7.dll 3: setup13.cab
Error 1334. The file 'ABCpdfCE7.dll' cannot be installed because the file cannot be found in cabinet file 'setup13.cab'. This could indicate a network error, an error reading from the CD-ROM, or a problem with this package.
MSI (s) (54:88) [14:37:41:073]: Product: PEAC-WMD -- Error 1334. The file 'ABCpdfCE7.dll' cannot be installed because the file cannot be found in cabinet file 'setup13.cab'. This could indicate a network error, an error reading from the CD-ROM, or a problem with this package.
What could be causing this. How can it be avoided.
Thanks!
mihai.petcu
Re: Strange 1334 error with Window 7
Postby mihai.petcu » Tue Mar 22, 2011 9:32 am
Hello and welcome to the Advanced Installer Forums,
Here is similar thread which explains a possible reason.
Please follow my colleague and if the solution scenario is not the same in your case, would it be possible to send us a sample project to support at advancedinstaller dot com for us to investigate?
Best,
Who is online
Users browsing this forum: No registered users and 2 guests
