Smadash
Installer crash on 64 bit machines
My product has a specific installation package for x64 systems.
Sometimes when we try to install it on Win7 x64 machines, the installer crashes before it
displays the first installer window. Sometimes however it works OK.
I attached a screen shot of the error message and also the event viewer message.
My installation package installs Visual Studio 2008 redistributable x86 and Visual Studio 2008 redistributable x64.
I use the Advanced Installer version 8.0.2 build 31861.
Any idea ?
Asher
Installer crash
Installer crash
Installer crash event viewer message
mihai.petcu
Re: Installer crash on 64 bit machines
Hello Asher,
Can you please describe a test case and also send us the .AIP (project) to support at advancedinstaller dot com so we can try to reproduce the behavior?
Best,
Smadash
Hello Mihai,
I have sent my AIP file to the support email address.
Asher
jsriptide
I believe I'm having the same issue on version 8.3. I've sent my AIP to the support email address. Was this issue ever resolved?
There was a problem related to prerequisite searches which has been fixed in version 8.3, it appeared when converting projects from an older version, for example 8.0 or 8.1.
The workaround in this case was to delete the prerequisites, save the project and then add them back manually, not using copy paste options.
However, if you have sent the project files by e-mail I'm sure that you have received my reply by now.
jsriptide
That appears to have worked. Thanks so much for your help.
My pleasure.
Have a nice weekend,
