jafa
Access denied creating updater scheduled task
When I enabled the "run updater as a windows scheduled task feature" the installation fails on Windows 7 with the following message:
"An error was encountered while creating a scheduled task: '<name of job>'. Error description: Access is denied."
Windows 7 x64
Advanced Installer version 6.7.1
The user account is set to "[ComputerName]\[LogonUser]"
I get the same error with "[%UserDomain]\[LogonUser]"
Nick
mihai.petcu
Re: Access denied creating updater scheduled task
Hi Nick,
Can you please send us the .AIP (project) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
Best,
themuffinman
I'm running into this same issue. My installation type is Per User and admin privileges are not requested. Do I need to have admin privileges to create a scheduled task? If so how do you setup updates when you don't have it?
In order to create a scheduled task, the user must indeed be an administrator/administrator rights must be provided.
If you want to handle updates without elevation, please refer to the following article:
How to handle updates without elevation
Please note, however, that this option is only available for projects which have the "Per-machine only" installation type, as stated in the article:
This article is only for projects that already have "Per machine only (fails if the user is not administrator)" installation type, set from the Install Parameters.
fede071
I have the "Per-machine if user is administrator, per user otherwise" and a scheduled task for the updater. Is there a way to ignore the scheduled task if the user is not an admin without showing the error message "an error was encountered while creating a scheduled task ..."?
Thank you in advance
Federica
Hello Federica,
In order to achieve this, you can use condition the Scheduled Task creation.
Right click on your scheduled task --> Properties --> Install condition option. Here you can add the AI_DETECTED_ADMIN_USER or AI_DETECTED_PRIVILEGED condition.
