Hi Advanced Installer guys:
I havent tryed this intresting product yet but I have some variables that I want you to see:
I have to install OpenOffice in my network enviroment. Here http://www.oooforum.org/forum/viewtopic.php?t=606 is an explanation how should I intall both "network-workstation" cause it should be done first as a local, then in each user that logs in tho the machine. In order to do this first I need to install first Install Java JRE.
Question:
I would like to make a big MSI but.....Wich installer should I use? The Advanced or the Java? Cause for the JRE I might need the JAVA but for the OpenOffice setup?
Also:
As you might have seen in the above link, I also have to run some script to acomodate the information after Network installation. Is there a way I can run some script (batch FE) in the middle of each installation in the same MSI?
Hope I have been enought clear, if not please tell me.
Thanks very much in advance.
Your homepage and product look very PRO.!! congratulations.
