janbrito
Deploy external component with VB .Net
I have an application in VB .Net and I'm using an external component, and ActiveX to be more specific. When I deploy my application in a different machine everything seems ok but when I try to run it I get an error "Class not registered". How can I make the intaller register this class?
Ionut
In the Files and Folders page, right click on the file in question and select "Properties" from the context menu. Then select the "Auto register file" checkbox. You can also select the desired registration method.
Ionut
Denis Toma
Advanced Installer Team
