Is there a way to remove the annoying "it is time to upgrade...." popup? I use Advanced installer from the command line in an automated environment. The upgrade popup is actually stopping execution of the rest of the script. You should at least be able to give Advanced Installer an argument to the command line to skip the upgrade check.
I think it is ok to have the popup when the GUI is started. The problem is when running the command line interface. Sometimes upgrading Advanced installer is not at highest priority. Still I want my automatic build to work in between version changes of Advanced installer. That is why I would appreciate if the popup was removed when running the command line interface.
