sa_ro
SQLExpress as prerequisite
for our application we need the SQLExpress database edition (newer version of MSDE), and the .Net Framework 2.0.
The problem is, that the SQLExpress itself need the ServicePack 2 on Windows XP or the ServicePack 4 on Windows 2000 as prerequisite. If I want to add the OS-ServicePack as prerequisite, I can't make a difference between the OS (XP or 2000) as Install-Condition. If I want to add the equal ServicePack as LaunchCondition, I even can make a difference on the OS (XP or 2000) with the property VersionNT, but the LaunchCondition will be checked even after installing the prerequisite software, and there will be listed the SQLExpress which needs the ServicePack!!!!
Hope you have a quick solution, our customer is waiting for his software!
King Regards,
Robin Saberi
dotVision e.K.
gigi
You don't need to add ServicePack as prerequisite to your main package. The msi of SQL Express should handle this.
Add SQLExpress and .Net Framework packages as prerequisite. With "Force installation of this prerequisites" option set your package will not be installed if the prerequisite is missing.
Gigi
_________________
Gheorghe Rada
Advanced Installer Team
