Pepa
Pop-up when removing last CD in multi-CD installation
Whe I run multi-CD install, sometimes when the last CD is ejected after installation is completed, message that setup.exe can't be found pops up. The setup.exe is on first CD only, but adding it to last CD doesn't seem to help.
Interestingly, the msiexe is still running at that time even though the installation was completed and last dialog closed. The product is installed correctly though, and closing the pop-up window doesn't cause any further problems.
It happens only sometimes, so far I was unable to track down any pattern.
However, I can't ship the installation with it...
Thanks for your help on this issue.
Joe
gigi
This was a bug in Advanced Installer that has been fixed beginning with version 4.3. So please upgrade your copy of Advanced Installer to last version.
If the problem still persist then please let me know.
Gigi
_______________
Gheorghe Rada
Advanced Installer Team
Pepa
Yes, the problem indeed still persists. Unfortunatelly I had to find out after the CD's shipped to customers. It happens on some machines, it doesn't happen on others. That's all I can tell you right now.
