ethurber
Cannot update Advanced Installer 4.3
When I click Help>Check For Updates I recieve the following error message:
Invalid updates configuration file. The first line of the .INI file should be ";aiu;"
The updater.ini file did not have this line so I added it. The file looks like this:
;aiu;
[General]
ApplicationName=Advanced Installer 4.3
DownloadsFolder=C:\Documents and Settings\<username>\Application Data\Caphyon\Advanced Installer\updates\
ID={<omitted>}
URL=http://www.advancedinstaller.com/downloads/updates.ini
AppDir=C:\Program Files\Caphyon\Advanced Installer\
CheckFrequency=2
CompanyName=Caphyon
Still will not update
Ionut
First of all, the "updater.ini" file that resides in the AI installation folder is not the updates configuration file and must not be modified.
Second, try to access the following URL using Internet Explorer:
Ionut
Denis Toma
Advanced Installer Team
ethurber
All set.
Thanks.
