ashtilman
conditions for maintenance mode
I have project that installs two databases using sql scripts. the databases are installed ok when I run the first install.
if I select only one database for installation in the first install and then run maintenance mode "modify" and try to install the second one the system doesnt run the scripts...
my condition is ((&AVPCONFIGDB = 3) AND NOT (!AVPCONFIGDB = 3)) , should I add something else in order to support it in maintenance mode?
thanks
ashtilman
Re: conditions for maintenance mode
solved it....just a small checkbox I forgot on the sql script section...
thanks
