FGump
Updates.ini on IIS 6
I had the AI updater working perfectly when my application ran the "updater.exe" which checked the "updates.ini" file on our server. The server had IIS5 on it. Recenlty we upgraded our server to Win2003 which has IIS6. I placed the same updates.ini file in the same folder structure, same permissions, security, etc... However, now everytime my application checks for an update it says "first line of updates.ini must start with ;aiu;".
I've checked everything repeatedly and it's okay! If I change the updates.ini to updates.txt, it WORKS! It seems IIS6 on Win2003 blocks the downloading of INI file. I read somewhere to add this to the MIME filetype list and I did, but AI still continues to fail to read it.
Is there a solution to this? Is it okay to rename the updates.ini file? I even tried updates.aiu and that too would not work.
Thank you very much,
Frank
gigi
The updater doesn't look for the .ini extension. So you can rename the updates.ini file to updates.txt with no problem.
However you need to configure your IIS server to allow the .ini extensions. Add the .ini extension to the MIME type list of the "Web Site" or "Virtual Directory" that contains the updates.ini file.
Best Regards,
Gigi
______________
Gheorghe Rada
Advanced Installer Team
