TMT
Contact: ICQ
ant integration bug
Hi I have to integrate Advance Installer with CruiseControl - ANT.
I use Advance Installer command line
       <exec program="${adv.installer.exe}"
           workingdir="${aip.files.path}" >
           <arg line="/build ourapplication.aip" />
       </exec>
everything works perfectly except situation when some files are missing - I obtain GUI message "Error Openning File ...." - a file from the project (.aip).
And the question is - can Advanced Installer write exception messages to some file or redirect somehow to the ANT?
According to features described in the help it should integrate :)
TMT
Contact: ICQ
OOpps...... The problem was solved - I started COM application instead of EXE :)
AdvancedInstaller.com
Thanks for your time :)
