capeuk
Error open .AIP project with Polish dictionary
I am preparing my application for my Polish market and got my words translation as expected and added them to my dictionary “cp_dictionary3.ail” enclosed in attached zip file. Saved and tried to open my installer project (Test-lite.aip - enclosed in attached zip file) returns error displayed in “dictionary.gif” attached.
I have used the same method to translate my installer for French, German, Spanish and Swedish and they all works why is it not the same for my Polish one, what am I doing wrong?
Moshud
test.zip
(8.61 KiB) Downloaded 341 times
mihai.petcu
Re: Error open .AIP project with Polish dictionary
Hi Moshud,
This is happening because the dictionary file contains invalid characters, exactly as presented in the error, starting with line 17.
You can notice the characters by opening the dictionary file in Notepad++.
Please note that all characters must support UTF-8 encoding.
capeuk
I have solved my problem myself, after several trials and error.
If you are translating your installer to another language other than the standard ANSI characters set, e.g. English, French, German, Spanish, Swedish and Italian etc. You would need to following the below steps
a. Create translation dictionary using Advanced installer. This dictionary is created in ANSI encoding in English version.
b. Resave as UTF-8 encoding.
c. Using notepad, click on file menu then select "Save As", now change "Encoding" type from "ANSI" to "UTF-8".
See screen shot below.
Moshud
