Smadash
"Run As Administrator" needed
My installer package uses custom actions that involve running installed executables.
The installation process fails if I do not run the installation package "As Administrator".
When I check the even log I see an error message indicating that one of the custom actions
related executables failed.
If I use "right click\Run as Administrator" everything works OK.
I use an administrator account for the installation process.
I am using Advanced Installer version 8.1.1build 34572.
Should I configure the installer differently ?
Thank you.
Asher
The event log error message
The installation process error message
mihai.petcu
Re: "Run As Administrator" needed
Hello Asher,
You can try to set your custom actions with "Deferred, with no impersonation" and see the result.
Smadash
Hello Mihai,
It solved the issue. Thank you.
Asher
mihai.petcu
Hi Asher,
You are welcome, glad to help.
Best,
