Actually this is a limitation of windows installer, for more details about this please see:
http://msdn.microsoft.com/library/defau ... _table.asp
As an workaround you can try this:
1. Create a msi that only create the user account and add it as prerequisites.
2. Create a
deferred custom action (of type "Launch File or Open URL") to set permissions for a specific folder. Scheduled this custom action under "InstallFinalize" with (Not Installed) as execution condition. For this custom action you can use CALCS.EXE system tool that sets permissions for a folder. To view what command line switches you can specify for the CA just type CALCS in the Windows command prompt.
Best Regards,
Gigi
______________
Gheorghe Rada
Advanced Installer Team
