deand
How To upgrade without losing feature settings
Could someone point me in the direction of some documentation that explains how to configure Advanced Installer to retain the current feature settings during an upgrade.
This would be a version upgrade from 1.0.1 to 1.0.2.
Thanks.
gigi
Please see:
http://www.advancedinstaller.com/user-g ... ional.html
http://www.advancedinstaller.com/user-g ... rsion.html
To create an upgrade use "File->Save As" option, make sure you have "Automatically upgrade older versions of the product" option set in the "Installer Parameters" page. After you "Save As" the project increase the "Product Version" and answer yes when AI ask you to generate a new "Product Code".
If you want to create a patch please see (for a patch answer no when AI ask to generate a new "Product Code"):
http://www.advancedinstaller.com/user-g ... patch.html
If you encounter any problems please let me know.
Best Regards,
Gigi
______________
Gheorghe Rada
Advanced Installer Team
deand
Thank you for your quick response Gheorghe.
Here's a more detailed explanation of the problem ...
When the customer installs version 1.0.1 they can choose to install feature 1, but not feature 2. On other PC's they may choose to install feature 2 but not feature 1.
At some point in the future I send the customer an upgrade to 1.0.2. When they run the upgrade it loses the feature settings that the customer chose when they originally installed.
This means that the customer must remember exactly which features were required on which machines when they upgrade. As a result, the customer will choose not to upgrade, which is what I want to avoid.
So, back to my original question, How do I ensure that the features chosen during the initial install are automatically selected (or not selected) during an upgrade?
Your assistance is much appreciated.
gigi
By default on upgrade ("Product Code" changed) the old package is uninstalled completely before installing the new one.
This can be done with patches. A patch is the difference between two msi packages and when you apply it the target msi need to be installed.
To read more about patches please see:
http://www.advancedinstaller.com/user-g ... oject.html
Note that you need to respect all the patch creation rules from the following link:
http://www.advancedinstaller.com/user-g ... tches.html
For a tutorial on how to create patches please see:
Please let me know if you encounter any problem.
Best Regards,
Gigi
______________
Gheorghe Rada
deand
The Microsoft MSDN documentation regarding the MSI SDK is very clear when it says ...
"To ensure differentiation of versions of the current product in the future, a minor upgrade should be used instead of a small update."
http://msdn.microsoft.com/library/defau ... grades.asp
A small update is the MSDN term for a patch.
This means that for my purposes, a patch does not perform the required function.
The MSDN documentation provides a Version Upgrade example, in which they begin by importing the Original Installation Database.
http://msdn.microsoft.com/library/defau ... xample.asp
Does Advanced Installer import the original installation database during an upgrade, and if it does, what settings are required to pre-configure the feature selections using the content of the original installation database ?
gigi
Patch packages are of three types:
1. Small Update when "ProductCode" and "ProductVersion" are not changed.
2. Minor Upgrade when "ProductCode" is not changed and "ProductVersion" is changed.
3. Major Upgrades when "ProductCode" and "ProductVersion" are both changed (those type of patches are not recommended).
To achieve what you want create a minor upgrade. Open your project and use "File->Save As" option. In the saved project increase the "Product Version" and choose no when AI ask to generate a new "Product Code". Build the project.
With the old and new version of your package create a patch.
Also note that you need to respect all the patch creation rules from the following link:
On how to create a patch please see:
Best Regards,
Gigi
_______________
Gheorghe Rada
deand
Thanks anyway Gheorghe, but the 'patch' interface is not what I want to present to my customer.
I want them to have the complete interface, which allows them to see their current feature configuration, and to alter it if they wish.
What does the MigrateFeatureStates standard action in the Custom Actions page do?
If I were to create a "Property Set with Formatted" custom action, what would I type to read the state of the "Communication" feature into a custom property named MyProperty?
gigi
I'm not sure if this can be done. Maybe with a custom action but this is not a easy task and need to know C++ coding.
Also I don't understand for what you need that because on upgrade ("ProductCode" changed) the old package is uninstalled completely before new one gets installed.
This is usually done on maintenances when user click on the modify button.
Gigi
______________
Gheorghe Rada
deand
It's a fair comment Gigi. The problem I have is that my customers are very stupid. They can't remember what the features were when the upgrade started.
I'm under a lot of pressure to streamline this process and ensure that feature settings are maintained across the upgrade cycle. :(
I have developed a solution however. What I'm doing is creating a registry value for each feature setting. I then use the search registry function to set a cutom property with the value of the registry entry. I then use a condition to lower the Install Level of the feature if the custom property has the required value.
This is working fine. I'm now stuck trying to create/edit the registry values during the Commit phase. (for testing I simply created the registry entries with regedit).
What I'm trying to do is use a Custom Action to generate the registry entries based on the feature selections. I'm using a VBScript Custom Action, but I can't figure out how to read the feature states from the database using VBScript.
Any help you could offer would be appreciated.
Dean.
gigi
Hi Dean,
To read a feature state in a VBS custom action you can use this code:
Session.Property("MY_PROP") = cstr(Session.FeatureRequestState("MainFeature"))
The feature state will stored in the MY_PROP property. Schedule the custom action that reads the features states under "InstallExecuteSequence->CostFinalize", this is executed before registry gets written. Now in the "Registry" view create a registry value with [MY_PROP] as its data.
Best Regards,
Gigi
______________
Gheorghe Rada
deand
Thanks Gigi, works a treat.
Dean.
