sandbox
search ini files
I need to search for an ini value. I am using the search facility but cannot however hard I try get the ini value.
The ini file is dynamically created and written after the installer has been created and will be copied into the installer directory. Therefore I have not added it to the 'Application Folder' in 'Files & Folders'.
I then need the installer to read in an ini value from the file and use it in the installation process.
I have created an ini search but whatever I do I cannot retrieve the result. I have added the file as 'id.ini' - does it need a folder? i.e. [SourceDir]id.ini or is it just id.ini?
gigi
Please see my reply:
http://www.advancedinstaller.com/forums ... php?t=1744
Gigi
______________
Gheorghe Rada
Advanced Installer Team
