MikeMurnane
Dialog for User Abort
I would like to see an addition to the standard dialogs ... a simple dialog that acknowledges that the User Aborted the install ... it could be used by programs that are executed via viewer.exe under custom action. It would need to be based on the return code - maybe positive numbers are user aborts, negative numbers are errors and zero remains as success. Such a dialog would make it clearer to the user what has happened ... as it is now, it appears that there is an error, when actually, the "error" is that the user has decided to abort the install.
Cosmin
Re: Dialog for User Abort
Unfortunately Windows Installer doesn't support this. To show an installation dialog you need to use a VBScript or DLL custom action which has access to the installer session. Also, this needs to be done through custom code because it handles a custom scenario.
Cosmin
Return to “Feature Requests”
