SubZero
Checking multiple Ports.
Hi all,
I found this tutorial that shows how to check if a tcp port is free: http://www.advancedinstaller.com/user-g ... -port.html
In our software we need to check multiple ports. Is it possible to extend the given example to check multiple ports without creating a dialog for every port? We would like to have all ports configured in one dialog.
mihai.petcu
Re: Checking multiple Ports.
If you want to have multiple input boxes for multiple ports, you can use a custom action to call the "Check TCP Port" UI Custom Action several times for each port.
Please note that the AI_BIND_TCP_PORT property is set after each Check TCP Port call.
In a C++ DLL, installer public properties can be accessed with MsiGetProperty and MsiSetProperty functions.
If you are using a C++ DLL Custom Action you can call "Check TCP Port" using:
MsiDoAction(hInstall, _T("YOUR_CUSTOM_ACTION"));
In VBScript, installer public properties can be accessed like this:
' read
value = Session.Property("PROPERTY_NAME")
' write
Session.Property("PROPERTY_NAME") = value
In a VBScript custom action you can call "Check TCP Port" using:
Session.DoAction("YOUR_CUSTOM_ACTION");
