rex
How to run a Custom Action before launch condition check?
The idea is to do some my own check with a Custom Action, and then use the check result for a launch condition.
Rex
gigi
The "Launch Conditions" are executed when the "LaunchConditions" standard action reaches. This standard action is present on both UI and Execute sequences. So if you want to execute a custom action before Launch Conditions schedule it before the "LaunchConditions" standard action (you can schedule it under "Begin" for example).
Best Regards,
Gigi
_______________
Gheorghe Rada
Advanced Installer Team
rex
Thanks. Will try it next week.
