phlow666
Setup is more than 20 seconds not visible.
i have a setup with an exe-bootstrapper and a msi-filesize of 340MB. When i call the setup.exe it takes up to 20 seconds until the "PrepareDlg" appears. I have a strong PC (Core i7, 8GB RAM...). I have no CustomActions in the "Begin"-Sequence.
An other point are some (1 or 2) little windows at the beginning of the setup which are shortly shown before "PrepareDlg" appears. For me and my collegues it looks like the setup crashes. If one of our customers is not so patient and does not wait 20 seconds, he starts the setup again. Could it be possible to have such a splashscreen or something else, that the user is notified, that the setup is starting up and not crashes?
mihai.petcu
Re: Setup is more than 20 seconds not visible.
Does the setup contain global prerequisites? This could take time on Advanced Installer's side.
Can you please send us the .AIP (project) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
Meanwhile, you can also test it on other machines as well and see the behavior.
As Mihai suspected the setup takes that long to start because it checks for the two global prerequisites you have in it.
If the user tries to launch it again it will receive a message from us telling him the package is already running.
If you look at the long sent to us you can see that the MSI has not delay, once it is launched. However, before the MSI is launched the setup checks the global prerequisites.
phlow666
Thanks for your fast answer.
This could be a reason. But in an other setup, with the same prerequisites, it takes less time. Could it also be possible that the time depends on the msi-size?
Could you also say something about the "flashing" small dialogs on the startup ofthe setup?
mihai.petcu
The size of the package shouldn't matter except in the case you have the "Include files in EXE" option enabled from the Bootstrapper tab in Media page.
I am not sure what you are referring to, can you please give us more details? Are you referring to the behavior debated in this thread?
phlow666
I don't have a "Include files in EXE" package.
But I'm not sure if you understand the dialogs I mean. I added them as a attachment.
Let me tell you the installsequence.
--> start "setup.exe"
appears (for less than a half second)
--> up to 20 or more seconds nothing (this is a dangerous part, because user thinks setup crashes)
--> the prepare dialog appears
My wish is:
--> show immediate PrepareDlg (max. 2 seconds nothing) or a splash screen which shows the user that something happens!
Is this possible? Thank you.
mihai.petcu
The delay is from the Windows Installer process and there is nothing we can do on Advanced Installer side regarding this. The screenshot behavior is from the setup and it's a single dialog which text changes.
You can try to reinstall/repair Windows Installer on that machine and test the package on other machines. If the problem persists, please send us the package so we can replicate the behavior.
phlow666
I tried to reinstall WindowsInstaller, but without success.
The setup-package is about 330MB big. I don't know how to send it to you. Is there a possibility?
mihai.petcu
You can upload it to an online location or use other tools like Dropbox.
If these options don't work for you, please contact us via e-mail so we can provide the ftp details to one of our servers.
mihai.petcu
After further investigation on this issue it seems the delay is caused by the time taken to check the package's digital signature. Unfortunately, there is nothing we can do to prevent this delay.
As far as the splash screen feature is concerned, I have discussed the issue with the development team and it would be very difficult to implement for this scenario.
phlow666
thanks for the tip, but without the signatures it takes more than 8 seconds without displaying anything on the screen. Any ideas?
phlow666
I'm currently sending an other file to you via WeTransfer. Hope you see something. Thanks.
Cosmin
Just because the files are not digitally signed doesn't mean Windows Installer doesn't check them for a digital signature. That check takes some time. This is a Windows Installer limitation, so there's not much we can do about it.
Cosmin
phlow666
Checking the prerequisites (.Net-Framework, WindowsInstaller) is also a timing problem? True?
mihai.petcu
This is true as I mentioned in my first reply on this thread, that time is taken before the bootstrapper starts. However, that part of the installation is executed normally in your case. The part taking a long time occurs after the global prerequisite bootstrapper dialog is closed.
