homam
Calling Uninstall "custom action"
Dear Support team
i want to call uninstall action while executing install if one condition is true. scenario will be like that, i should check during the installation action if one program is installed or not by using the "registry search property" if it is installed i should call the uninstallation action directly else the installation action will continue normally
regards
Hamam
Cosmin
Re: Calling Uninstall "custom action"
Hi Hamam,
Is that program an older version of your product? If it is, does it use a MSI package? In this can you can use the automatic upgrade feature.
If it's another product, how do you want to detect it? What would like to search for?
Cosmin
homam
Dear Cosmin
thanks for your reply, yes I will search for it using the registry values then in case it is already there i want to execute Uninstaller related to it
regards
Hamam
Return to “Feature Requests”
