homam
customize upgrade
hi All
it is quite urgent to me, how could I customize the upgrade process to do just install to the new version without any uninstallation.
regards
Hamam
Re: customize upgrade
Hi Hamam,
This can be done very easy, all you need to do is to change the upgradecode of the project. You can change it from
Project -> Options -> Project IDs tab.
Return to “Feature Requests”
