bullyellis
Hang on "Publishing Product Information" when chaining MSI's
I am currently chaining 2 MSI's "CRRuntime_32bit_13_0.msi" and "IBM_Informix_Client_SDK_64.msi" with my install.
Everything works fine, they both kick off and install after my main program has been installed. My issue is that after they have installed and I am back at my install screen, the installer hangs on "Publishing Product Information".
Anyone have any ideas on how I can prevent this, or force the install to continue and ultimately end?
Re: Hang on "Publishing Product Information" when chaining M
Do you mean the MSI hangs when you try to enter maintenance phase? If so, can you reproduce this on multiple clean machines?
So we can investigate this further more can you please send us the aip file and a verbose log created while the MSI hangs to support at advancedinstaller dot com.
bullyellis
Emailed. Also sent the .aip file.
bullyellis
Bogdan wrote:Hi,
No, this is during the initial installation.
Arthur
Was there a resolution to this? I am having the same problem.
Arthur
Hello Arthur,
We are not sure what generates this behavior. Can you please test the chained packages you added in the main one separately? Also, add them one by one, to see which of them makes the packages to fail installing. And test the package on at least two different and clean machines.
Also, please give us more details about your scenario.
