Nick Price
Signed driver not installing.
I'm working with the trail.
I've used the new driver wizard to add my inf file to the project. See attached images.
But it doesn't install, no new hardware wizard appears.
What an i doing wrong?
Do I need to add dpinst myself?
Regards
Nick
Re: Signed driver not installing.
Hi Nick,
Please note that the framework is designed for installing Software First Install drivers only. These drivers usually come with your application, e.g. an anti-virus filter for the network adapter.
It is not recommended to use it for installing Hardware First Install type drivers, e.g. a driver for your sound card.
Nick Price
Hi Bogdan.
But doesn't your app call dpinst 2.1? which is the same I would manually call.
I have found a possible reason for the failed install.
I've been using an app note from FTDI for creating a signed catalogue file for my inf. But it's no signed the driver itself, only signed in cat file. This is a work around for Win7 64bit refusing to load unsigned drivers.
Have to use inf2cat , and then signed with the signtool. I got it to successfully load the driver on Win7 64bit.
But at the end of the day should I expect your driver install to work, or call the dpinst during my install. How do I call a exe from my install. I know there's a problem calling dpinst directly, so I created a wrapper exe for it.
Cheers
Nick
Cosmin
Hi Nick,
No, it uses the DIFx framework API. The core installation process is similar, but not the same.
You can use a Launch file or open URL custom action.
Cosmin
Nick Price
Ok, will do.
Many thanks
Nick
