SubZero
Volume Combo Box
Hi all,
we are using a volume combo box in order to let the user choose the destination for an additional program. The volume combo box always starts without a value, is it possible to always initialize it with the first value ( in our case the first volume)?
mihai.petcu
Re: Volume Combo Box
To accomplish this, simply add a new SetProperty init event on the same dialog as the Volume Select Combo control. This event should set the control's attached public property to the value you need.
Something like:
C:\
or
[WindowsVolume]
Volume Select Combo.jpg (64.65 KiB) Viewed 5943 times
SubZero
thanks! Works fine :)
cpatterson
Is it possible to list only the drives greater than a certain size in the VolumeSelectCombo? Since the VolumeCostList knows the sizes of the drives, can I somehow use that information to restrict the values in the VolumeSelectCombo?
Hello Candace,
As we already discussed over e-mail, we don't have any predefined support for this. The only way to achieve this is by creating your own custom action with desired functionality.
