dms
Option to publish notes
The notes feature makes it very easy to carefully document the install process, what would make it better still would be the abiity to publish the notes to a text or xml file. Thus if the notes were reasonably well written you'd have the basis for a comprehensive text or xml document detailing the instructions needed to create a particular type o install.
Dom
Cosmin
Re: Option to publish notes
Hi Dom,
I added this improvement on our TODO list and it will be available in a future version. Thank you for your suggestion.
Cosmin
Return to “Feature Requests”
