homam
Reduce the size of the Exe file
Hi;
I already include all the files inside the exe by choosing
• Builds -> Boostrapper -> package -> include install files in exe
my question how i could reduce the size of the created exe file in a proper way
thanks in advance
Hamam
Re: Reduce the size of the Exe file
Hi Hamam,
For this you can use our LZMA compression option, from Configuration tab, in Builds page. Here you can select different levels of compression,
depending on how much you wish to reduce the size of the package.
http://www.advancedinstaller.com/user-g ... ssion.html
http://www.advancedinstaller.com/best-i ... ssion.html
http://www.advancedinstaller.com/user-g ... eters.html
Return to “Feature Requests”
