PeterGans
error message
Project imported and modified from MSI created by InstallShield.
Error message
Database: Unknown table 'Extension' in SQL query: SELECT ''Extension' , 'Extension' FROM 'Extension' WHERE 'Extension' , 'Prog_Id_'=?.
Cosmin
Re: error message
I'm not sure why this happens. Can you please send us a link to your MSI to support at advancedinstaller dot com so we can investigate it?
Cosmin
PeterGans
Re: error message
It only happens when I do a test run from the GUI (XP). Installation on another machine (Vista) was OK. I have yet to test it on Win.7, so no action is needed unless that installation fails, in which case I'll do as you ask.
PeterGans
Re: error message
This error only occurs under Windows XP. The installer can be downloaded from http://www.hyperquad.co.uk/hyss.htm
(Vista and Windows7 version). I have retained the old installer for XP, for the moment, but this should not be a long-term solution.
I would prefer correspondence to be directed to: peter.gans at hyperquad.co.uk
Cosmin
Re: error message
I noticed that your packages are EXE, not MSI. How are you importing the MSI? Please note that InstallShield is known for linking the MSI to its bootstrapper. So an MSI extracted from an EXE installer may not contain the full functionality or work correctly.
Cosmin
mdordoy
Re: error message
I am also getting this issue. It only happens on windows xp, when i run my package on windows 7 the error goes away. Does anyone know what might be causing this or how i can fix it?
Many thanks
Mark
Cosmin
Re: error message
Hi Mark,
I'm not sure why this happens. Can you please send us a link to your MSI to support at advancedinstaller dot com so we can investigate it? Also attach your .AIP (project) file to your email.
Cosmin
sstrauss87
Re: error message
I have this same issue have we found a solution yet?
mihai.petcu
Re: error message
Can you please send us a link so we can download the package and replicate the issue? For confidentiality matters you can redirect this conversation via e-mail. Our address is support at advancedinstaller dot com.
sstrauss87
Re: error message
Im not sure if I can give you access to the installer, but I will try. I happens during the "Registering Program Identifiers" part of the installation. Any Idea at all?
mihai.petcu
Re: error message
Unfortunately not, but if you send us the required resources we may be able to replicate and debug this issue.
sstrauss87
Re: error message
I have emailed All the files I think you will need, you will receive an email from ********@generaldigital.com
sstrauss87
Re: error message
Nevermind, your email srvr rejected the message, what is the max size you can receive, the email was under 40MB but maybe I can chop it up into a few smaller emails
mihai.petcu
Re: error message
The attachment restriction is much smaller around 10 MB. You can upload it to an online location and send us the link (e.g. Dropbox).
sstrauss87
Re: error message
I've set up a drop box and email tech support with the details
