chaspc
Ability to re-download an update file
Occasionally I am getting an error after the download of an update file. This error occurs during the subsequent attempt by the updater to execute the file.
If I run the updater again, it finds the file in the roaming folder and will not download it again.
The only way I can currently redownload the file is to explain to the user how to get to Users/... Roaming/updates/Updater and have them delete the file and then rerun the updater. The updater then downloads the file again and runs it successfully.
Charles
Cosmin
Re: Ability to re-download an update file
Hi Charles,
By default each update uses an MD5 signature verification which ensures that the update package was downloaded correctly. Is your update package downloaded correctly or is the file incomplete? Does the problem occur when launching the downloaded package manually?
Cosmin
chaspc
I haven't been able to duplicate the problem until now. I released an update yesterday and have two customers that cannot execute the update. All my other customers are fine.
The program appears to download, but then gives an error when trying to execute the program.
One of my customers is sending me a screenshot of the error. I will forward that to you when I receive it.
It seems that the updater should delete the existing file whenever the "download now" button is pressed. Instead, it appears to detect the file in the update folder and skip the download, leaving the customer with a bad file.
chaspc
The screenshot was of no use - it just says "Some of the updates failed to install properly".
It is turning out that our biggest headache is the updater. Its great for 95% of our customers but we are now having almost 5% of our users get an error after downloading the exe file - and there is no way to force a redownload. I have them download to another folder (or delete the existing one) and that seems to take care of the problem - for that update - for that user.
I will continue trying to find the cause of the error. Perhaps your next version could have more detailed error reporting.
bchetana
Hey ,
I too face the same issue? did you find the root cause ?? Any Solution ????
chaspc
No, actually, it just went away with one of the later releases of the installer. We haven't seen that issue in a very long time.
bchetana
Hi ,
I am using AI 9.8 with Enterprise License.
This happening very rarely and we could not find the senario at what time we face this issue. Can you guide me ?
I'm not sure why you are encountering this behavior. Can you please make sure that the "Compute MD5 signature from file" option is enabled in your updates configuration project and see if the behavior still persist?
bchetana
Hi Daniel,
My Updates configuration project is already with following settings :
ScreenHunter_01 Mar. 08 11.14.gif (29.77 KiB) Viewed 20712 times
Can you please give us more details about the behavior you are encountering (maybe you can attach a screenshot with the error message)? Also, it would be useful if you could a test case scenario so we can try to reproduce and investigate this?
cf454
Was this every resolved?
I have the same issue.
Please give us more details about the behavior you are facing with.
Also, if you could isolate the behavior in a small builadble sample (AIPs + their referenced files) and send it us alongsied a detailed test case to follow this iwll be great.
Return to “Feature Requests”
