It does support files larger than 2 GB, but only when using LZMA:
- go to "Media" page and select Media tab
- select "Archive installation files using LZMA compression for smallest package size" option
- build your project
Well maybe that is so, but every time we use the LZMA we get an error if the file size was larger than 2 GB. Error reading some file.
In any case, your software is an admirable piece of art. Thank you
Can you please send us the .AIP (project) file you are using to support at advancedinstaller dot com so we can investigate it? Also, please attach a screen-shot with the error you receive.
