Alpicus
AI 8.3 : New files not syncronized in Organization
After installing 8.3 and adding new files in a folder which is syncronized with a feature, the files are not added automatically in the feature.
Thanks for your future reply.
Best Regards.
Phil
Cosmin
Re: AI 8.3 : New files not syncronized in Organization
Hi Phil,
I'm not sure why you are encountering this behavior. Can you please send us the .AIP (project) file you are using to support at advancedinstaller dot com so we can investigate it?
Cosmin
Alpicus
Hi Cosmin,
Thanks for ur reply.
Email with attachement sent.
TIA,
Phil
mihai.petcu
Hi Phil,
Unfortunately, we cannot replicate this behavior on our test machines. Can you please isolate the behavior on a fresh project with dummy files and send it to us via e-mail so we can take a look? Also, please send a description of each step we need to perform in order to replicate this issue.
Alpicus
The added files went to the feature selected in the toolbar : Problem resloved > Just moved the components to the right feature.
Thanks for ur support.
Best Regards,
Phil
