testarosa
updates.exe cannot run incompatibility with 64 bit versions
I just did an update for my software package. The auto updater runs fine, downloads, but I'm getting The program or feature "updates.exe" cannot start or run due to incompatibility with 64 bit versions of Windows on install.
I have the previous full installation installed on this same machine, is there somewhere when you're creating an update to specify 64 Bit?? I don't know where this error is coming from.
Please see attached.
As always, thanks!
-C
Cosmin
Re: updates.exe cannot run incompatibility with 64 bit versi
Is "Updates.exe" an installation package created with Advanced Installer? If it is, can you please send us the updates configuration file and Updater INI to support at advancedinstaller dot com so we can investigate them?
If it's not an installer, can you please give me more details about it?
Cosmin
testarosa
the original and updates are both Advanced Installer. They're on the way.
ChrisJ
Re: updates.exe cannot run incompatibility with 64 bit versions
Hello Testarosa,
Can I ask if you found the answer to this problem ?
Because I am getting the same message with my Setup.EXE created with Advanced Installer.
Many thanks.
If you are encountering a similar error, can you please manually download and launch your updates setup file? If the same error is thrown when the updates setup is manually launched, then there is an architecture issue of your setup package.
Please send us the AIPs (project files) of your old product version, of the new product version and of the updates configuration project to support at advancedinstaller dot com so we can investigate them. Also, please let us know on which Windows version are you running the Updater to install updates.
