tanith
Error: the filename or extension...
I have created a patch and added it to the auto updater, but I get the following error when I run the autoupdate:
Error: The filename or extension is too long.
My updates.txt file is in place and contains the following:
;aiu;
[Update]
Name=Gaia 3D Viewer 2.2.0002
URL=http://www.gaia3d.co.uk/download/patch220002.msp
Size=12320768
MD5=b400bb84531abd402be8f1185ce0f108
ServerFileName=patch220002.msp
Flags=IsPatch
FilePath=[APPDIR]Gaia3D.exe
Version=2.2.0001
Description=Update to the Gaia 3D Viewer
BugFix=Fixed trenches not playing sounds.
AutoCloseApplication=[APPDIR]Gaia3D.exe|;;NoRestart
mihai.petcu
Re: Error: the filename or extension...
Hi and welcome to Advanced Installer forums,
Can you please send us the .INI file next to the "Updater.exe" to support at advancedinstaller dot com so we can investigate it?
mihai.petcu
As suspected, after looking into the .INI file it seems the Downloads Folder path is too long. Can you please shorten it for testing purposes and see the result?
If this is not the case this could be a permission issue.
tanith
This fixed the issue, I changed it to:
DownloadsFolder=C:\updates\
Thank you
