ghash
Asking for several needs/features
i want to know if advances installer matches my needs so i decided to register here and ask.
I need an open Install-System, where i can put or remove some executables, and depending which exe is in a specific folder, the installer offers a programm / multiple programs to install and sets some variables for further decisions.
Next i need is, depending on %SYSTEMDRIVE% (often c:\ ) i want to install there and have to edit some *.ini files to configure my program(s).
Is it possible with advanced installer, especially with the free version to test this features?
Thanks for reply
ghash
Re: Asking for several needs/features
Hi and welcome to our forums,
Could you please give us an example so we can understand exactly what your requirements are?
This can be done, for editing and updating INI files we offer a built-in editor, in Files and Folders page. The predefined folder from Files and Folders page called "WindowsVolume" it always resolves to the partition on which the OS is installed, so it can help you too.
Regarding the features available during trial period, all of them are accessible to you based on the project type created. For your case you will need
to create an Enterprise one. You can download the trial version from the following page.
If you have any questions please let us know.
Return to “Feature Requests”
