yoramkr
using log file when running from CD
Hi
I use the Bootstrap MSI command line to create a LOG file when the installer runs.
The command is: /L*V setup.log.
Now that we started deploying our software in a CD we can't run the installer directly from the CD because the installer can't create the log file on the CD itself (of course).
How can I use a property to set the log file path?
I want to be able to set the log file path in a different folder (e.g C:\temp) but only if the installer runs from a location I can't create the log file.
Yoram
mihai.petcu
Re: using log file when running from CD
Hi Yoram,
You can try to create your own .BAT or .EXE that creates the log in the desired hard-drive location from the command line :
http://www.advancedinstaller.com/user-guide/qa-log.html
You can then use this .BAT or .EXE to execute as part of a custom autorun:
http://www.advancedinstaller.com/user-g ... ialog.html
This way if the installation runs from the CD/DVD and cannot create the log using the relative path from the Media page -> Bootstrapper tab, it will create it in the location mentioned in the .BAT or .EXE.
