phlow666
Copy / Move dialog did not copy
I'm using the "Edit File Copy / Move" dialog. I want to copy the content of a directory to an other directory. But it don't works.
I placed the shown operation in destination folder.
Re: Copy / Move dialog did not copy
The copy operation seems to be correctly configured, the only reason it would not be executed is if the component "Event_Management" was not installed,
therefore the copy operation would not be triggered.
Can you please make sure the component is installed? Also, can you please try the package on another clean machine?
