jonA
Access Violation on upgrade from 8.0.2 to 8.4
I have several projects which are currently in 8.0.2. I installed 8.4, and went to build a new version of our installs, and while several of the installs compiled successfully, one of them throws the following :
Exception - [SEH_AV_READ_BADPTR] ACCESS_VIOLATION (0xc0000005) at address 0x826365640040c60b.
*** Stack Trace (x86) ***
[0x0040c60b]
This was from a batch job, so I restored a previous version of the file, and opened it in the UI, at which point I was able to compile the project without issue.
I saved the project, and reopened it, and compiled again, and I was again greeted with the access violation.
It appears something is corrupting in the file, after the upgrade saves the 8.4 changes to it.
~ Jon
Re: Access Violation on upgrade from 8.0.2 to 8.4
Hi Jon,
I'm not sure why this is happening, can you please send us the two aip files, i.e. the original version from 8.0.2 and the corrupted one, after you have saved
the file using version 8.4 of Advanced Installer. You can send them to support at advancedinstaller dot com and we shall analyze them as soon as possible.
jbabco
Having exact same issue with 8.02 -> 8.6. 8.6 opens and converts the project. If I then save it I cannot re-open it:
Getting the same error when trying to build this converted project on the command line.
Cosmin
I'm not sure why you are encountering this behavior. Can you please send us the .AIP (project) file you are using to support at advancedinstaller dot com so we can investigate it?
Cosmin
This error appeared because of the problem discussed in the following thread:
http://www.advancedinstaller.com/forums ... med#p47883
