When I build a long existing install, part way through the process Windows has to go through an install / repair of VS 2010.
Never had this problem until I installed 8.4 It does not seem to cause a problem as far as I can tell, but it really slows down the build. And it happens EVERY time I build, even within the same session.
Window Title: Microsoft Visual Studio 2010 Professional - ENU
Window Message: Please wait while Windows configures Microsoft Visual Studio 2010
Professional 2010
Gathering Required Information: Progress bar shows, along with a Cancel Option
Below is the text from the build along with a note as to when this occurs.
[ DefaultBuild ]
Building package (en): C:\Users\Ben\Documents\Advanced Installer\Projects\Certified Payroll Solution\Setup Files\Setup.exe
Reusing archives from cache... done.
Creating MSI database... done.
Writing Summary Information... done.
This is where the installer comes up.
Adding merge modules... done.
Signing MSI... done.
Creating EXE file... done.
Build time: 3 min 54 sec.
Total build time: 3 min 54 sec.
Build finished successfully.
Thank you for your help.
