Alpicus
AI 8.4 : exception on building
When building a media, an error is displayed. Please check the attached file.
After rebuilding the media, it's working.
TIA,
Phil
build exception.jpg (100.09 KiB) Viewed 5413 times
Cosmin
Re: AI 8.4 : exception on building
Hi Phil,
This may happen if the file cannot be written in the package because the output folder is opened in Windows Explorer. I also noticed that you are building the package in a network path. Try building it in a local folder and use a post-build event to copy it in the network path.
Cosmin
Alpicus
Thanks for the reply. That's it : the folder was opened with the Windows Explorer.
Thanks.
Phil
McKool
I thought this was fixed within AI 8.2 :?
Release 8.2 Notes
Bug fixes
* Error when building EXE packages while the output folder was opened in Windows Explorer
mihai.petcu
Unfortunately this problems is caused by an open handle used by Windows Explorer. We encountered a lot of tools which have the same problem. Although we made some small improvements for this, we were unable to find a complete solution. Perhaps in a future version.
