dawies
V8.4 crashing continiously
Hi there,
I am using V8.4 on win7 and it crashes irregularly while I'm working causing me to have to reopen the program and project I was working on and loosing my work. It happens at different times while doing different things in different projects and is starting to annoy me something silly.
Does it log the errors somewhere so I can send it to you to have a look at?
regards,
Dawie
mihai.petcu
Re: V8.4 crashing continiously
Hi Dawie,
Advanced Installer has been throughly tested on several Windows 7 machines and should be working fine.
Unfortunately, we don't have any logging system to help you out. If you cannot isolate a test case pattern, there is nothing much we can do.
You could send some screenshots of the errors and also provide more information about the OS. Also, maybe the Event Viewer tool can shed some light on the matter.
Have you tried installing Advanced Installer on other Windows 7 machines?
dawies
Thank you,
I will post screen shots as and when they happen.
This happened after editing a checkbox
mihai.petcu
Can you please send us the .AIP (project) to support at advancedinstaller dot com so we can investigate it?
dawies
These happened when I deleted a "Show only if..." condition from dialogs.
dawies
This is the project after the crash
SuperSign Client.aip
(29.32 KiB) Downloaded 922 times
Cosmin
Unfortunately we are unable to reproduce this behavior with the project you attached. Do you have by any chance an older backup on which you can reproduce the errors? Also, does the project you attached show any errors? If it does, what are you doing to trigger them?
Cosmin
dawies
Hi Cosmin,
Thank you for your efforts.
This actually happened on more than one of my projects. I will try and install on another PC and see if the problem persists. Just have some serious deadlines and no spare PC at the moment.
regards,
dawie
dawies
Hi Cosmin,
I now have a new PC that I want to move the Advanced Installer software to. How do I go about re licensing via email?
regards,
Dawie
Cosmin
Hi Dawie,
After opening Advanced Installer use the "Help" -> "Register" menu to launch the registration wizard. On the first page select the "by email" option and press Next to get the ComputerID. Copy this ID and send it by email with your license key to support at advancedinstaller dot com.
Cosmin
