jlavery
Path variables attached custom VBS actions and SQL
Hi there,
We're using path variables for our application files to install.
However, we have vbs files and SQL scripts which we want to run, which are also under the same path as our files to install.
is there a way to use path variables to define the location of the attached action vbs files and sql scripts we want to run?
James
mihai.petcu
Re: Path variables attached custom VBS actions and SQL
Hi James,
Unfortunately, you can specify a path variable only for an attached custom action. Currently there is no predefined support on specifying path variables for SQL scripts.
Hello James,
The "Path variables support for SQL Scripts" improvement was included in version 10.6 of Advanced Installer released on September 30, 2013.
