sjblack@gmail.com
InstallState & InstallLog files left behind on uninstall.
I have an advance installer project with three custom actions that are run on install and they use 3 installed files, file1.exe, file2.dll, file3.exe say. Once the install is complete there are four extra files placed in the appdir directory named, file1.Installstate, file1.InstallLog, file2.InstallState and file2.InstallLog.
This causes a problem when the project is uninstalled as the previous application directory is not deleted and these four files remain.
Any ideas on how to remove the directory without forcing it would be great.
Sj
Cosmin
Re: InstallState & InstallLog files left behind on uninstall
A solution is to use file removal operations in Files and Folders page. This way you can remove only the files you want using native Windows Installer support.
Cosmin
sjblack@gmail.com
That was my solution could you explain why these files are left behind? I have 40+ installer projects if this is going to happen a lot its going to start getting annoying. It would be good if there is something I could do to avoid it.
Thanks very much.
Sj
mihai.petcu
By default the uninstallation removes all resources declared in the Files and Folders page.
This is happening because the files are created via custom behavior attached to the installer. All files created by custom means, must also have a defined removal.
sjblack@gmail.com
Hi There,
This was my fault these files were being generated by installUtil.exe. To stop the log file being created I added an empty path on the LogFile switch.
InstallUtil.exe /LogFile="" [assemblyPath]
and I added an uninstall custom on the same command with the uninstall switch set which removed the .installstate file.
InstallUtil.exe /uninstall /LogFile="" [assemblyPath]
Sorry about that.
Sj
mihai.petcu
No problem, let us know if you have any other doubts or queries.
