DrBob
Application search for PublicDocumentsFolder fails
Hi
I cant seem to get Application Search for a folder under [PublicDocumentsFolder] working. When I use the test botton it fails, rather than return the path to the folder. Folder searches work fine for folders under other locations (eg system32). See screenshot of example search for "Sensory Software" folder under PublicDocuments on my XP machine.
mihai.petcu
Re: Application search for PublicDocumentsFolder fails
This behavior is caused by a bug in Advanced Installer. Thank you for bringing it to our attention, I have added it on our version 8.7 TODO list and it should be out by the end of next month.
