honzajic
Application pool name should be validated
I have found there is problem with your Advanced Installer regarding Name of Application Pool.
If you are creating an Application Pool with Advanced Installer, you can specify any string.
But when you are creating Application Pool with IIS manager, you cannot use some characters (see screenshot).
I have used in my Project character '@' which is not valid character and installation process shows error message
that this invalid Application pool is already existing on that machine...
Thank you.
Honza
Re: Application pool name should be validated
Hi Honza,
Thank you for your suggestions, I've added the improvement on our TODO list, so it should be implemented in one of the next versions.
If you have other questions/suggestions please let us know.
Hi Honza,
After a later discussion with my colleagues from development it was decided that a validation will not be performed on this field. This is because it is a formatted field, and no formatted field from Advanced Installer is validated, because at install time the property can change its value.
