jsheldon
Malformed control tab-order on dialog: "FatalError".
When I open the attached project I get this Error: Malformed control tab-order on dialog: "fatelError".
I just upgraded to 8.6
I have not been able to open this file in 8.6 but it was working fine in 8.5 - I have opened other 8.5 saves files with 8.6 with no problem.
Can you find what's wrong with the file please?
CrystalStudio.aip
(62.82 KiB) Downloaded 420 times
Re: Malformed control tab-order on dialog: "FatalError".
Here we explain why this error appears:
http://www.advancedinstaller.com/forums ... =2&t=19854
Attached you can find your fixed project. If you have any other projects that manifest the same behavior just send them by e-mail.
CrystalStudio-Fixed.aip
(62.82 KiB) Downloaded 409 times
jsheldon
Thanks, here's the last one with this problem.
FlexPlot.aip
(39.87 KiB) Downloaded 355 times
Attached you can find the fixed project.
FlexPlot - Fixed.aip
(39.88 KiB) Downloaded 350 times
