jojoba2010
Register OCX --- Please HELP !!!!!!!!
Advanced installer build success but when we run the setup on other comp get error !
(When i wanna to register ocx via advanced installer i get this error.)
[tiny.ocx].
"The cabinet file "disk1.cab" required for this installation is corrupt and
can not be used. This could indicate a network error, an error reading from CD-ROM, or a problem with this package"
I have attached the .aip file here.
mihai.petcu
Re: Register OCX
Unfortunately we cannot open your .AIP be cause of some modification in the table editor. However, there seems to be a problem with your installer's .CAB file. You can try to include it in the .MSI database from the Media page and see if the error persists.
Does the .OCX register manually outside the installer?
jojoba2010
Re: Register OCX
my advanced installer is V 8.3.
Please Help Me.
mihai.petcu
Re: Register OCX --- I have Errorr and the solution doesnt h
Can you please try the two suggestions I mentioned above and see if the problem persists?
jojoba2010
Not Help!
I have attached it (the .aip file) once more.
Please check and help me.
Thanks!
Demo900820.aip
(73.47 KiB) Downloaded 501 times
jojoba2010
Re: Register OCX --- Please HELP !!!!!!!!
Please Help!
Is it very hard question that nobody can ans.
Best Regards
jojoba
mihai.petcu
The sample .AIP you attached does not have the "Include CAB file into the MSI database" option enabled in the Media page.
Can you please specify the outcome on both of my suggestions from my first post?
