den
Ability to handle bootstrapper run result
Our company encountered the following problem.
We provide trial version of our product and we collect statistics about how much people downloaded trial version and how much people actually launched it.
Problem is that amount of people who actually launched trial version is about 20-30% of all who starts downloading.
Of course, some of them doesn't even finish the installer download (it is quite large now), but others doesn't finish install process.
If in the MSI UI or install sequence we can use custom actions to collect stats about if installation was finished properly or not, then bootstrapper doesn't have such abilities.
We have large prerequisite (.NET Framework 4.0 Client profile) installed as web-installer through bootstrapper and we suppose that some people doesn't install it, but we need facts.
If bootstrapper could communicate the results of its work to some other process (our custom exe), that would be what we need.
Den.
Re: Ability to handle bootstrapper run result
Hi Den,
You could try to create your own EXE wrapper over our setup package, so your EXE launches our setup and waits for it to return a value.
The EXE bootstrapper will return -1 if the user presses the "Cancel" button, while installing the prerequisites. Otherwise it will
return the code returned by MSIExec.exe after running the main MSI.
Return to “Feature Requests”
