maffeis
How to use regular expressions in Edit Text File Update
Hi
can somebody give me examples of regular expressions I can put into the "Edit Text File Update" text replacement tool?
The online help says its ECMAscript. I would like to see examples of ho to map a Java style regexp such as
John [.]+
into ECMAscript. Thanks!
Silvano
screen shot
screen shot
mihai.petcu
Re: How to use regular expressions in Edit Text File Update
Hi Silvano,
Unfortunately we don't have any samples in our user guide, but you can search the Internet to learn about ECMAScript.
Here's a good place to start.
Jimmy
Hi there
I run into a similar problem:
I got a config file, which contains credentials, which was installed by a previous version.
now, we have to update those entries, which can be variable.
I tried to find a solution to delete all lines which contains the string ".password="
The regular expression should be (as I recherched):
^.*\.password=.*$
but: nothing happens at all.
It would be very kind to give me some advices.
THanks in advance
Jimmy
Hello Jimmy,
Can you use the following regular expression:
^.*\.password=.*(\r\n)?
and see if the behavior still persist?
