tsohler1977
UI - Reset DialogTheme - EnterpriseSetup
how do I reset the design, if it has adjusted itself.
At the beginning the 'SetupTypeDlg' dialogue has been viewed as follows
I accidentally removed the 'SetupTypeDlg' from First Time Install sequence. When I added it again, the view has changed.
Where are the icons and how can i reset the layout?
The TreeView also lack the sub-node 'install mode = install mode custom' and 'install mode = install mode complete'.
Even if I create a new project the dialog looks like that in Figure 2
Please help me,
Thorsten
mihai.petcu
Re: UI - Reset DialogTheme - EnterpriseSetup
Hi Thorsten,
Have you tried running the package to test its UI? Can you please underline the Modern theme issue at runtime?
tsohler1977
Hi Mihai,
at runtime, the icons in the UI are displayed correctly. So I'm clear.
But how do I get the dialogue sub nodes 'install mode = install mode custom' and 'install mode = install mode complete' to light? The dialog behavior on Next-Button-Events is considerably more complicated at the moment than before.
Thorsten
mihai.petcu
Hi Thorsten,
The runtime functionality should also be the expected one. The correct dialog subchain structure to assure the expected functionality is the one from your first screenshot.
I have tested this in the Modern theme and unfortunately cannot get the structure from your second screenshot. Can you please send us the .AIP ( project file ) to support at advancedinstaller dot com so we can investigate it?
